Question PC not booting after switching main power button
Apr 4, 2024
5
Hi folks,
I'm facing a problem with my PC which doesn't want to boot. When I switch on the main power button [ I | O ], the fans does 10 degree rotation and stops. The front LED blinks. The GPU fans are turning.
Neither start or reset button us doing anything.
Where could be the issue ? Wire or power issue ?
Hi folks,
Did it used to work fine before? (or is it a new build?)
- Check the front panel connections to see if they are connected properly.
- Make sure all the cables are plugged in properly, and all components seated properly. (disconnect the cables and components, and reconnect them to ensure)
exactly.
Since this worked before,
Likely during the move the front panel power button and cable came loose or was damaged.
- Unplugged all pins LED, PW and RESET from power section of the motherboard
- Connecting PW pins for a solid 2 sec doesn't start the booting neither.
Just to confirm, can I connect PW + to any GND pin ?
