Pc not booting please help
Mahbub1
435
My ram was showing 12 gb usable while installed was 16 gb. I went to mscinfig and clicked use full memorg option in advancmed options. And from there my pc blue screening and bsod-ing. I guess one ram stick is bad. But not even if i take iut that and out and out other ram sticks its not booting. I checked by putting indivdual sticks but it isint booting. Whats the problem. Please help.. also after a few reboots a popup came up the systen crashed due to overclocking. But my gou fans are still running proccy is fine too. Shoukd j change my ram?
Start the computer in safe mode by turning the machine on and tapping the f8 key. Once windows loads, launch msconfig and change the maximum memory setting back to its default setting.
Yes i returned bios to factory settings still same issue. I tried one ram stick individuakky still same. Is gpu gone? If so then whg are its fans spinning. It boots uoti win 7 animation and bsod
