So here whats happening:
a WHILE back i had this problem where my pc wouldnt go to sleep on its own and it would just turn off the monitor but the pc is still "awake"(even tho i set the monitor to never go to sleep). Now, back then i had managed to fix this by going to the power plan and changing the settings of the plan. the problem got fixed. Now i have this same problem AGAIN and when i check the power plan settings they were the same settings as i left then when i first fixed the problem. keep in mind the timeout time for the monitor is "never". so if the settings are still the same and nothing has changed....what could be causing this problem?????
