Hi, my PC is not posting since a rebuild with upgrades. Their is no display.
My guess is something got broken but I don't know what......
Spec
Asus P8P67 motherboard,
Intel CPU,
Corsair non+ecc ram (4x4GB),
Enermax Galaxy 850w PSU,
Asus graphics card,
The upgrades-changes
The upgrade was a new case (Phantek Ethoo) and Corsair H100i cooler along with increasing ram. Mainly because the PC was overheating and due to a huge amount of dust. Due to this, I also took the PSU casing off and used compressed air to clear off the dust.
First problems
I made several mistakes with the rebuild as I mention below.
1) My first mistake was I had no display because I forgot to plug in the 2x power connectors to the GPU (I heard windows boot through the plugged in speakers). After taking the pc apart I realised and corrected my mistake. I tested the build, had a display, I was in bios (CPU temp was great) so I switched pc off by holding the power button and started connecting up additional hard drives etc.
2) I then had a problem with the DRAM led constantly red (so went to replace the the ram after clearing cmos and using the memok function on the board). I later sprayed compressed air on the motherboard and reseated the ram, the DRAM led now goes off after a sec but I believe this issue was caused by dust or incorrectly seated ram.
The current problem!
The pc has no display as has been the case since the rebuild with the exception of directly after (1).
The motherboard shows power, the DRAM led flashes on and then goes off, and the fans continuously spin. The connected keyboard has power (but caps lock doesn't turn function on-off). No audible beeps or other lights showing.
Strangely when powering on, the GPU fans on occasion stayed still, (this appears to have sorted itself I believe by reinserting the power cable) but it should of been consistent.
Troubleshooting
Removed from case to ensure no shorts.
Cleared cmos by removing battery and also using jumpers.
Plugged in motherboard speaker to help with troubleshooting.
Checked cables are all plugged in and seated correctly.
Tried another GPU (not conclusive as it may of been dead).
Strange symtoms
With the motherboard speaker plugged in and no ram, the PC beeps to indicate no ram so for this reason I think its not the motherboard. However with the ram in, removing the hard drive, graphics card there are no beeps and no additional lights on the board to inidicate a problem.
I thought it should beep or a led would show.....
As I mentioned the GPU fans didn't always spin. So I was thinking maybe i messed up the PSU when cleaning it... I was so careful though... It's all inconsistent and weird.
Thank you for all your help!!
Spec
Intel CPU,
Asus graphics card,
First problems
Troubleshooting
Strange symtoms
