Question PC Not turning on (fans turn on for half a second)
Aug 13, 2019
6
Hello, recently i was building a gaming computer with my friend. Some of the specs are amd fx 6300, gtx 1060, 8gb ddr3 ram, 650 watt corsair psu and an asus M5a97 le r2.0. we built everything and it didnt start we re wired the pc and then i believe it started due to me turning the 8 pin cpu connector into a 4pin one. When the pc was built it had 2 old hardrives 250gb + 125gb. they had old files and windows 7. when the pc turned on my keyboard lit up but wouldnt type or select modes. it automatically turned on file corruption repair. it did this process once and when the pc restarted it gave the same screen. this time we let it run but it froze. after that the pc hasnt been able to turn on. when you press the on button the fans start going for maybe 1 second and straght away turn off. the mother board and gpu have lights on. Please help my friend is stressing.
