Question PC Not turning on - only making a click noise
Nov 17, 2024
7
Hello, while I was in the middle of using my PC, it randomly shut off and since then I have tried to turn it back on, but it just makes a click noise and that's it, no movement of fans at all. I tried pulling out and reconnecting all the cables on the motherboard, PSU, and GPU which didn't do anything. I tried booting the computer with just the 24 pin cable and AC and that didn't work either. I did do the paper clip test, and I could feel a small breeze coming from the PSU (so I'm assuming fans are working in the PSU for the paper clip test).
The PC is quite dirty at the moment, so I could try cleaning it completely but just wondering if anybody has any ideas for what's going on with it.
All components are 4 years old except the GPU and PSU which are 5 years old.
Thanks.
The click noise is probably a relay that shorts out the NTC Thermistor input surge arrestor. That part at least appears to be working OK, as does the fan.
I think it quite likely your PSU has died and needs to be replaced. Buy/borrow/swap the PSU with another unit.
You don't mention the part number or manufacturer of your PSU, but if it came with only 1, 2 or 3 years warranty, after 5 years it may be too late to RMA.
Consider a PSU with a 10-year warranty.
I'd leave well alone for the time being, unless it's this dirty.
iu
People visit this forum seeking help, when their computers stop working immediately after a session of over enthusiastic "cleaning".
Mild dusting of the fans on the CPU cooler shouldn't cause any harm, but completely disassembling the PC for a deep clean could cause even more problems.
Reactions: annatar1
iu
Thanks for the response, the PSU is a Corsair TX550M Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply if that helps at all.
Yes, I've got a TX550M in an old i5-4670K computer and it's working OK, but your PSU may have died.
As I said earlier, try another PSU.
I've no idea what you rig contains, but if you have a powerful GPU, a 550W PSU may not be sufficient. If your CPU and GPU are both capable of drawing up to 200W each. a higher capacity replacement PSU might be wise.
Reactions: annatar1
I removed the GPU (2060 Super, 5 years old) completely and tried to turn on the PC and it turned on. Unfortunately, my CPU (Ryzen 3 3100) doesn't have integrated graphics.
So only removing the GPU completely from the motherboard is enough to get the PC on, not just unplugging the PCIE cable.
