Did you remove ANY ram?i just added a new wi-fi card, psi, and ram to my pc and now it starts up but the monitor just goes black and that’s it. any help on this?
CPU - amd ryzen 5 3600You need to give us more information as opposed to generically stating what you've done to your system. It helps us if we're not assuming things and getting towards a potential culprit.
Please list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
i also have a wireless fenvi 802.11AX/AC wi-fi adapterYou need to give us more information as opposed to generically stating what you've done to your system. It helps us if we're not assuming things and getting towards a potential culprit.
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
yes i switched the ram from old oloy 2x8gb to corsair vengeance rgb pro 2x8gbDid you remove ANY ram?
Fully describe any new ram you installed. Brand, model number, size, speed, etc
What is a "psi"?
i meant psu sorry for the typoDid you remove ANY ram?
What is a "psi"?
Not enough detail on the old.yes i switched the ram from old oloy 2x8gb to corsair vengeance rgb pro 2x8gb
oloy 2x8gb had ddr4 2400mhzNot enough detail on the old.
Not enough detail on the new.
yeah i put the new ram sticks into the same slots as the old one and yeah the mobo is compatible with the new RAMNot sure what you wanted to accomplish by changing from this 16GB of RAM to that 16 GB of RAM.
Did you put the 2 new sticks into the same 2 slots that the old sticks were in?
Did you go to Asrock web site and investigate the compatible RAM list for your motherboard?
I am aware of 13 Asrock "B450" motherboards.yeah i put the new ram sticks into the same slots as the old one and yeah the mobo is compatible with the new RAM
i have the ASRock b450m pro4 am4I am aware of 13 Asrock "B450" motherboards.
For which of those 10 did you check the qualified memory list?
What motivated you to change RAM at all?i have the ASRock b450m pro4 am4
well long story short my d drive and c drive would both reach 100% when i would play any games resulting in slowed everything, pc freezing entirely, and graphics not loading and not being able to load into the games at all. this happened for a few months until a week ago when it just started working again. i also bought this pc prebuilt so it had decent cpu and gpu and mobo but everything else was budget based and i had no idea what was messing up my d drive and c drive so i bought new parts for the pc and just installed a new PSU , ram, wi-fi card, and i will be installing a new ssd once i get an enclosure.What motivated you to change RAM at all?
Is your particular Corsair DDR 4 3200 2x8 kit on the list for that particular board? I'm too lazy to look for myself.
You could go to Crucial.com and use their configurator to tell you what Crucial ram is compatible. But it won't help for the Corsair you've already bought.
and on pcpartpicker it says my mobo and ram are compatibleWhat motivated you to change RAM at all?
Replacing parts until the problem goes away is always a solution. If the SSD, doesn't help, you can try motherboard, CPU, and CPU cooler. Don't forget virus scans, runaway processes, unknown applications running in the background, malware, etc.i bought new parts for the pc and just installed a new PSU , ram, wi-fi card, and i will be installing a new ssd once i get an enclosure.
yeah i used norton for a month and it said i had a virus that they got rid of but nothing really changed and now my pc isn’t turning on. do you think it could be because i didn’t properly put in the ram? when i turn on my pc the screen goes blackReplacing parts until the problem goes away is always a solution. If the SSD, doesn't help, you can try motherboard, CPU, and CPU cooler. Don't forget virus scans, runaway processes, unknown applications running in the background, malware, etc.
A clean Windows install is always a possibility.
i think tomorrow i’ll do so and see which part is actually not correctly put in it just doesn’t work with other components but i think i messed up somewhere near the psu when i was installing the moplex and sata cables.Your first post in this thread says:
"i just added a new wi-fi card, psi, and ram to my pc and now it starts up but the monitor just goes black and that’s it. any help on this?"
My first impulse would be to go back to the last combination of old parts that did NOT lead to a black screen.....................using as few parts as possible.
One ram stick.
One hard drive.
One CPU.
One PSU.
One motherboard.
No wireless card or anything else.
Outside of the case on a tabletop.
We have little or no idea which of your parts are broken. You have to determine that by experimentation since you don't have testing equipment. Trial and error.
You replaced PSU.think i messed up somewhere near the psu when i was installing the moplex and sata cables.
could be possible that i did plug it into the wrong place lolSomething simple, you connected the monitor to the gpu? Not the motherboard?
And would be good to recheck all cable connections, also on the psu side since modular.
the old psu was not modular and had the cables all connected to one hole on the psu while the new one was modular so i had to plug in all the right ones that came with it. so using other cables from different psu can kill your pc or just using the wrong cables in general? i hope i didn’t pay even more money just to ruin my pc even more.You replaced PSU.
Were both PSUs (old and new) modular?
Are you using original modular cables supplied with your PSU?
Modular cables are not compatible between different PSU models.
Using wrong modular cables can result in damage/death to devices connected.
