Pc part picking need help
Apr 30, 2018
Hi guys, i need some of your opinions for buiding a new system because my old one got broken.
Here are my considerations:
CPU:
Ryzen 3 2200G vs 1200
Motherboard:
Gigabyte GA-A320M-S2H
VS
ASUS prime A320 K
Memory:
1x8gb Crucial Ballistix 2400Mhz ddr4
VS
2x4gb Avexir Core 2400Mhz DDR4
Power supply:
Seasonic S12ii 520Watts
VS
Raidmax 500watts RX500XT
Both storage and case I already have one. I’m conflicted with my parts, especially the CPU part because going to pcpartpicker, it says that I need to upgrade the bios of the motherboards using a different pc which i no longer have one (hence my build)
For gaming, i’m not much of a gamer. I just play Overwatch, counter strike, and DOTA. Nothing too extensive, hence my preference for 2200G. I do have a tight budget that’s why i either go for 2200G with no GPU (because the types of games i play can handle them) or 1200 but with 1050ti (meaning I have to shell out more money, which I’m tight with)
What are your guys’ thought?
PS.
If i do get to pick 2200G, is it also easy to upgrade and put in for example a 1050ti in the future?
Thank you so much for everyone’s help.
Ram 2x4gb, seasonic psu, and get the ryzen 2400G instead. Will get you 60fps in all those e sports games.
You can update ur mobo in a local shop.
Try to go for a b350 mobo to overclock ur gpu and ram.
If those parts are the only ones you can get, then I'd choose 2200G, Asus Prime A320K, 2x4GB Avexir, SeaSonic S12II.
This is what I'd recommend instead:
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor ($94.59 @ SuperBiiz)
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard ($60.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory ($103.99 @ Newegg)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply ($34.99 @ Newegg)
Total: $294.55
Generated by PCPartPicker 2018-04-30 21:57 EDT-0400
