PC Parts 1st PC Need Help Quick
Michealll
5
Ive got parts. I just want to see if these parts are good for a fast running gaming pc. If I should replace these items please give feedback.
Motherboard: MSI Pro Series Intel B250 LGA 1151 DDR4 USB 3.1 micro-ATX Motherboard | $65
CPU: Intel BX80677G4560 7th Gen Pentium Desktop Processors | $77
RAM: Ballistix Sport LT 8GB Kit (4GBx2) DDR4 2400 MT/s (PC4-19200) DIMM 288-Pin - BLS2K4G4D240FSC | $70
GPU: MSI GAMING Radeon RX 470 GDDR5 4GB CrossFire FinFET DirectX 12 Graphics Card | $231
PSU:EVGA 430 W1, 80+ WHITE 430W | $30
Hard Drive: Any WD Blue = $50
Case: DIYPC DIY-J21-W White USB 3.0 ATX Mid Tower Gaming Computer Case with Pre-installed 3 Fans | $40
The CPU, Pentium G4560 is a bit weak and not intended for gaming use but it will do. Combined with RX 470, you're looking medium settings @ 1080p or high/ultra settings @ 720p.
For gaming, you'll do much better with 4 core i5-7500 than 2 core G4560,
comparison: http://cpu.userbenchmark.com/Compare/Intel-Pentium-G4560-vs-Intel-Core-i5-7500/3892vs3648
And for GPU, RX 580 would do also better,
comparison: http://gpu.userbenchmark.com/Compare/AMD-RX-470-vs-AMD-RX-580/3640vs3923
With i5-7500 and RX 580, you're looking at high/ultra settings @ 1080p with solid 60+ FPS.
Note: for RX 580, you'll need at least 550W PSU, e.g Seasonic G-550,
pcpp: https://pcpartpicker.com/product/DPCwrH/seasonic-power-supply-ssr550rm
