PC parts compatibility check and another question
gtaandrei
Commendable
Jan 30, 2017
30
Are they compatible:case Segotep The Wind Black
gtx 1070 zotac 3xIcestorm
i5 6402p
msi h110m pro-vd
power supply cx750m
1 Tb HDD
...and is there a way to buy something similar in, but cheaper....but please don't change the gtx 1070
First of all, all of these components are compatible :)
If possible, I would change the CPU to an i5 6600 as its clock speed is higher. At the moment it's also CHEAPER on Amazon.co.uk (who ship to Romania).
You wouldn't have to switch out the motherboard or anything.
Second, I'm sure you want some RAM. That board supports 32GB at 2133 Mhz but personally I would go for 8GB+ if you want to game. (I have 16GB).
The board can take 2 sticks so this would do the trick. (I have put one 8GB stick so...
The board can take 2 sticks so this would do the trick. (I have put one 8GB stick so that you could add another one later if you need more!)
Third, you will need a cooler, but anything like this would do!
Lastly, if this is the GPU you are referring to, then it will be great!
Good luck!
http://www.pcgarage.ro/placi-video/zotac/geforce-gtx-1070-8gb-ddr5-256-bit-1/...this is and thank you
