Pc parts compatibility check
What Resolution do you intend to Play????
For 1080p, GTX 970 is fine.
But for 1440p you need a GTX 980Ti.
Are you planning to SLI GTX 970, then 1000W PSU is fine. but for a Single unit that thing is Overkill.
Why do you want 32gb of RAM for a gaming only pc? I dont even get to16gb @1440p with max settings.
The PSU is complete overkill. A 500-600w unit would run this without any issues and if you plan to SLI the 970 in the future a 800w unti would still be easily doing the job. Even with anything OCd.
And i'd also recommend getting a Samsung Pro SSD instead of the Corsair.
Cheaper and faster: http://www.anandtech.com/show/6428/corsair-neutron-neutron-gtx-all-capacities-tested/2
