PC parts compatibility
Sep 18, 2018
So I am building my first gaming PC and before I go and buy my parts I wanted to know if all the parts were 100% compatible. Here is the list:
CPU: AMD Ryzen 5 2600 3.4GHz 6-Core
Motherboard: Asus ROG Strix B450-F gaming ATX AM4
Memory: Kingston HyperX Fury Black 16GB(2 x 8GB) DDR4-2133
Storage: Samgung 860 Evo 500GB 2.5 as SSD and Western Digital Caviar Blue 1TB 3.5 7200 RPM as HDD
Video Card: Gigabyte GeForce GTX 1080 WINDFORCE OC (8GB, High End)
Case: Cooler Master MasterCase H500P Atx Mid Tower Case
Power Supply: be quiet! Pure Power 10 CM 600W 80+Silver Certified Semi-Modular Atx
Also if I could save some money somewhere also tell me :D. Thanks in advance
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor ($164.89 @ OutletPC)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard ($69.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($149.89 @ OutletPC)
Storage: Samsung - 860 Evo 500GB M.2-2280 Solid State Drive ($107.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card ($478.99 @ SuperBiiz)
Case: Cooler Master - MasterCase H500P ATX Mid Tower Case ($149.99 @ B&H)
Power Supply: SeaSonic - FOCUS Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply ($58.20 @ B&H)
Total: $1224.83
Generated by PCPartPicker 2018-09-18 17:07 EDT-0400
I'd go with this.
Barty1884
All compatible, yes.
As mentioned, 3000-3200MHz DDR4 would certainly be beneficial for Ryzen.
As far as changes/price etc... some thoughts:
1. The Strix B450-F is typically a little pricier than comparable boards. It's also ATX, which, on the B450 chipset, isn't particularly useful (IMO).
2. Crucial MX SSD offerings are typically a bit cheaper than 860 EVOs. While in benchmarks, they're a little slower - in day to day use, they'll 'feel' just as fast.
3. You might want to hold off just a little bit on the GPU purchase. With 20xx cards dropping, you might see some impact to 10xx card prices (although you may not).
4. The PSU is solid enough. Depending on your location, you may be able to do better for the money though.
