PC Parts Compatibility
Oct 27, 2018
4
I'm building my first pc and would like someone to double check that these parts are compatible. Thanks in advance. Also, if anyone has this case, how many fans can it hold?
Another thing, I'm not interested in overclocking the CPU.
CPU - Intel i5-8400
GPU - ASUS GeForce GTX 1070 Dual 0-O8G OC Edition 8gb
CPU COOLER - Cryorig h7 white
STORAGE - WD black NVMe 1tb ssd
MOTHERBOARD - MSI B360 gaming arctic ATX LGA1151 socket
MEMORY - Crucial ballistix sport LT 16gb kit white
POWER SUPPLY - SeaSonic PRIME SNOWSILENT 750W 80+ titanium certified fully modular ATX
CASE FAN - cryorig silent
CASE - Corsair carbide SPEC 06 RGB ATX mid tower
EDIT: I think I'll get the same power supply but at a 550w capacity as that's the lowest in the color and I would like to keep a white aesthetic. Would 550w be a good amount?
I will also go with a 250gb ssd and an hdd. For the ssd I would probably get WD, but should I worry about getting a WD black? Or could I just get a WD blue or red instead?
If you went with a smaller PSU, 250gb SSD & HDD you could either save quite a bit of money or put it somewhere's else in the build, like getting the 8700 instead of the 8400.
MERGED QUESTION
Question from adrianelaughman : "PC Parts Compatibility"
