pc parts fitting
No problem at all!
Alright here's what you could do:
Install Windows on this little thing (SSD 😀) £42: https://www.amazon.co.uk/Kingston-Technology-Solid-State-Drive/dp/B00A1ZTZOG
Then for games and God knows what else stuff it all on a 1TB Barracuda £46: https://www.amazon.co.uk/Seagate-ST1000DM003-inch-Barracuda-Drive/dp/B005T3GRNW/ref=sr_1_1?s=computers&ie=UTF8&qid=1474894882&sr=1-1&keywords=1tb+seagate
Then you will have a fast windows boot and also lots of storage for stuff! 😀
This would be best for a PC because then you can manage cables properly :)
sound like the stupest question ever.... but how would i install windows? ive only ever had prebuilt pcs before
You will have to buy a copy of Windows that can easily be found on Amazon and you simply put the disc in the machine and tell the PC to boot from the CD and then go through all of the options it gives and it will install windows onto your HDD for you :)
Take a loot at this for guidance on how to arrange the boot order: http://www.howtogeek.com/129815/beginner-geek-how-to-change-the-boot-order-in-your-computers-bios/ :)
but how do i make the os install on the ssd instead of the hdd? and is there anyway i could message you when i get my pc? i would prefer to message someone who clearly knows what they are doing
I can't be certain if i'll be available when you get your PC, that's the problem 🙁
But for that question, when you go to install windows it will ask where you want to install it to and it will just be a matter of clicking on the SSD icon then it will install on that drive :)
Leave the hard drive unconnected from the motherboard and it will install on the SSD.
Instead od buying a aftermarket CPU cooler use the stock and and buy the i5 6500 processor the 6400 is rather slow.
are there any cases that come pre installed with all the fans i need?
Better case, better PSU , slightly better mb, 240gb ssd.
The pau is £47 on amazon, a newer model & much better than the CX 500..
Steer clear of the cx430/500/600 models.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor (£174.00 @ Amazon UK)
Motherboard: Asus H110M-PLUS Micro ATX LGA1151 Motherboard (£53.24 @ Amazon UK)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory (£67.91 @ More Computers)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive (£56.09 @ Amazon UK)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive (£59.38 @ YoYoTech)
Video Card: EVGA GeForce GTX 1060 3GB GAMING Video Card (£191.51 @ CCL Computers)
Case: Cooler Master N200 MicroATX Mid Tower Case (£43.59 @ Amazon UK)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply (£49.56 @ BT Shop)
Operating System: Microsoft Windows 10 Home OEM 64-bit
Total: £695.28
Generated by PCPartPicker 2016-09-27 10:09 BST+0100
and that is everything i should need for my pc? would i need to buy anything else? and would it be able to run most games well?
Neither of those builds include the os price mate.
My build is better for £4 more .
How much exactly do you have to spend ??
There are compromises that can be made to keep you in budget if you need the os too.
You will need an optical drive to install windows from disk
i have an optical drive in my old pc which i will use, and oh i never noticed haha. is your build alot better?
