pc parts fitting
Well, the RAM will clearly fit in the case, but just make sure you remove the old RAM first.
The GPU would fit, just make sure you have a PCI-E X16 slot available on the motherboard. I'll check and respond back to you with the answer.
Yes, there is a GPU slot available. Make sure you remove the old RAM before inserting the new sticks, and if you bought the version with the pre-installed Radeon R7 240, make sure you press down on the clip behind the GPU, and take the 240 out, then insert the new 1060.
The clip is key here. I accidentally broke one off on my first build back in the day because I didn't know any better.
thanks for the reply guys, will this pc be able to run may games like dying light and the division?
