I was playing destiny 2 like I do every night for 6 hours (lol). And all of a sudden I smelled a very weird burning smell was also very strong. Since I use air cooling and I OC my gpu and I have a notoriously hot cpu (fx 9590) I monitor all my systems, temps clocks and voltages...all was normal when smell developed ..GPU was at 50c , cpu at 43c all clocks and voltages were the same, I have so many fans I could not see any smoke or anything. Destiny and all programs continued to run without errors. Then after about 10 minutes of physically checking pc and downloading more diagnostic systems and everything looked normal on screen and in case, then screen went black and my steel series game DAC went blank and mouse rbgs started flickering (only two devices plugged into my USB 3 slots) everything else was in usb 2.0 and stayed on. All fans and lights stayed on, and My north bridge was really hot, Even tho all was on I could tell system was not running as fans started to throttle as components started to cool down. Usually I would hold the power button on my pc to turn off in this situation but I wouldnt work. I held it for a minute and nothing changed. Finally I had to hit the switch on back of PSU. I booted up again and it posted as usually and I opened chrome and started to investigate the issue and then same issue happened. Booted a 3rd time and went into bios and all was normal then same issue....screen goes black, power button doesnt work, fans throttle and components get cold but stay on. Meanwhile the entire room was filled with that strange but strong burning smell.
I had been using the pc for 5 months with same settings and hardware and no issues. Mobo is 7 years old but I cant see any burnt parts or issues with it and my mobo doesnt have temp sensors so I cant see if it is over heating. Any clues would be much appreciated and I am sorry but I typed this on my phone as I have stopped trying to use my pc. Thanks
I have AMD FX 9590
EVGA GTX 1080 FTW 2 ICx
Boot from HHD western Digital veloca raptor
Have a 250 GB SSD I store games on
700 watt psu
Gigabyte 990fx UDA 3 mobo
2x 8gb corsair 2400 gdr3 RAM
Here is the info, i imagine it should be easy to figure out
newest component is the GPU I got 4 months ago, I am an avid gamer I OC my GPU core clock no more than 36mhz and dont mess with voltage
I have AMD FX 9590
700 watt psu
