Question PC POWER CYCLING ISSUE
dinkbutt
13
I am having an issue with my PC. When I turn it on, it power cycles a few times and that is it. I assumed it was the PSU even though the old one tested OK, as I heard the test can be a false positive. The motherboard looks in good condition, none of the capacitors are bulging or leaking. I have tested the motherboard with only the CPU installed and the same thing occurs.
Any insight would be much appreciated! I almost just dropped a bunch of money on a new build, but, what a waste of money!
Thanks for your time.
dinkbutt
13
Motherboard - Asus Z87I Deluxe
CPU - Intel i5-4700k i think..
RAM - Kingston HyperX Black 16gb x2 (It is a kit, yes)
GPU - GeForce GTX 1070 FTW
I'm unsure what the memory QVL is.
dinkbutt
13
It's probably worth mentioning that I've had this same build for several years now without issue. The only thing I have upgraded is the GPU.
dinkbutt
13
Can't seem to find the ram kit number from the provided links, but going off of my RAM modules:
KIT OF 2 1.5V
KHX16C10B1BK2/16
Jason H.
So is it listed on the QVL per link I provided?
Obviously he said hes been using it for years without an issue so Im sure a "compatibility" issue wouldnt just pop up at random.....
Have you reset the cmos to make sure nothing got messed up in the bios?
Also have you tried using 1 stick of ram at a time to rule out a possibly failing chip?
dinkbutt
13
I thought I did reset the BIOS, I can't remember for sure, but will try that today. Same with trying one memory card at a time. What is the minimum amount of hardware needed to run these tests? Would it be the CPU, power button/reset button?
dinkbutt
13
I held the BIOS flashback button, cleared CMOS, and tried one RAM card at a time. It fires up, but only for a second. Am I doing something wrong? I mean more than likely, the question is, what am I doing wrong? lol
dinkbutt
13
I've never had an issue with this build until now. I've probably been running these components for almost 8 years now without problems.
It's beyond me what it could be..
dinkbutt
13
My PC no longer power cycles, I press the power button and it shuts down right away. Have you all given up on me? lol
Any help is much appreciated.
