PC Power Cycling
Someusername_
17
I just built my new PC and I noticed whenever I restart it, it begins to power cycle about 6 times and then it actually turns on. I have an Asrock AB350M Pro4 and I also have my PSU plugged into a power block. Is this normal or is this an issue?
Try it without the power block. Also make sure you have the latest bios. Make sure you have version 3 of the motherboard bios.
http://www.asrock.com/MB/AMD/AB350M%20Pro4/index.asp#BI..
Just updated my BIOS to 3.0, still having the same problem.
