Question PC Power Supply Build Advice
letmepicyou
229
39
4,620
You really don't need a 3070ti for 1080p gaming.
A 3060 is PLENTY for that resolution.
And an 850 watt is plenty for either gpu.
Lesson 1 in choosing a GPU - pick your GPU according to the RESOLUTION YOU GAME AT.
Hey there,
I'd be going with a strong 850w, like a Corsair RMx 850w for your build. Well able to handle transient power spikes of RTX GPU's and strong enough for some slightly more power hungry parts down the line. Stellar PSU for OC. Very strong.
Lesson two, games become more intense to run than the games that are out today. For instance Deadspace remake that came out today recommends a 3060-70 for 30 fps at 1440p. This means you will barley get 55-65 at 1080p. Buy the best graphics card you can with your budget so games don't become unplayable in a year or two.
Reactions: Roland Of Gilead
Well, yes and no :)
If someone is gaming at 1080p, the 3070ti guarantees Ultra settings, with room to spare for most games. One of the benefits of Nvidia GPU's is DLDSR. This quite a good option. For example, I've a 3060ti, which similarly is plenty for 1080p Ultra, and really good 1440p game play. Simply allow DSR factors in NVCP, choose higher res (even up to 4k) and watch how your GPU performs at higher res. DLDSR makes games look better after scaling, as long as the GPU has enough headroom. It really works well.
3070ti Gives that option.
letmepicyou
229
39
4,620
I certainly don't disagree, and if he could afford it I'd say "Get a 4090!", but he seemed to indicate that he was on a semi-restrictive budget, and when you're trying to save some caps, you can make some sacrifices in the GPU department at 1080p. That's all I'm sayin.
Well if you look at the price of the 3070 ti he chose its way overpriced compared to a 6800 xt which is 140 less.
Hi. I have done a custom PC build using PCPartPicker and it rates the overall build power consumption at 601W. I have learnt by going through other threads that you want a power supply that will cover for more power than the build is rated for due to power spikes from the CPU and GPU however will the 850w Power Supply I have selected be enough (build below):
(Note: I am trying to keep the build price as close to £2000 as possible, less if possible)
As far as your question goes, an 850 watt PSU would be a great decision with that build, however, I question getting one of Be Quiets entry level PSUs. I would sped a bit more on your PSU(Corsair RMX or RM) and a bit less on the GPU. Personally with your budget I would do something like this:
PCPartPicker Part List
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor (£312.99 @ Technextday)
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler (£120.10 @ CCL Computers)
Motherboard: Gigabyte Z790 UD AX ATX LGA1700 Motherboard (£237.48 @ Amazon UK)
Memory: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory (£132.87 @ Technextday)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£58.97 @ Amazon UK)
Storage: Kingston NV2 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£107.99 @ MoreCoCo)
Video Card: PowerColor Red Devil OC Radeon RX 6800 XT 16 GB Video Card (£579.59 @ Newegg UK)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case (£85.97 @ Novatech)
Power Supply: Corsair RM850e 850 W 80+ Gold Certified Fully Modular ATX Power Supply (£113.52 @ Technextday)
Operating System: Microsoft Windows 11 Home Retail - Download 64-bit (£109.99 @ MoreCoCo)
Monitor: AOC Q27G2U/BK 27.0" 2560 x 1440 144 Hz Monitor (£228.99 @ Currys PC World Business)
Total: £2088.46
Generated by PCPartPicker 2023-01-27 18:22 GMT+0000
Reactions: letmepicyou
Why_Me
Polypheme
https://uk.pcpartpicker.com/product/mpcG3C/fractal-design-pop-air-atx-mid-tower-case-fd-c-por1a-06
Fractal Design Pop Air ATX Mid Tower Case £89.99
https://uk.pcpartpicker.com/product/MkFbt6/deepcool-ag620-bk-argb-6788-cfm-cpu-cooler-r-ag620-bkanmn-g-2
DeepCool AG620 BK ARGB Dual Tower CPU Cooler £64.98
https://www.deepcool.com/products/Cooling/cpuaircoolers/AG620-BK-ARGB-Dual-Tower-CPU-Cooler/2022/16082.shtml
https://uk.pcpartpicker.com/product/qs92FT/kingston-fury-beast-32-gb-2-x-16-gb-ddr5-5600-cl36-memory-kf556c36bbek2-32
Kingston FURY Beast DDR5 5600 32GB (2x16GB) CL36 £132.87
letmepicyou
229
39
4,620
Total: £2088.46
I certainly agree on the power supply choice - the power supply is one place you shouldn't be afraid to throw money.
Reactions: helper800
