[SOLVED] PC powers on completely but no signal to monitor
Sep 17, 2020
I just built a new PC and when I was testing it, it powered up correctly, lights on motherboard, GPU, and all leds lit up and fans spun. When i plugged in my monitor though there was no signal. I tried plugging into mother board and GPU but neither worked. I even tried only using 1 ram stick to see if they weren’t in the correct slots. No clue what could be wrong, Thanks for any help.
Parts:
Geforce RTX 2070 Super (Graphics)
Gigabyte B365M DS3H (Motherboard)
Intel i5-9600k 9th Gen (Processor)
Corsair RM750 750 W 80+ Gold (PSU)
2x8 GB OLOy DDR4 Ram
Try different ports from the GPU to the monitor, Try a different monitor or a TV and try a Cable different from what you're using HDMI/DP whatever you're using.
