Hello, I recently built my first pc. it's spec are:
Ryzen 7 2700
MSI tomahawk 350 motherboard
MSI GTX 1060 6GB
16GB (8GBx2) Ballistix sport ram
120GB kingston ssd
1TB wd blue hard drive
Corsair CX550 power supply
Corsair carbide series 100r case
I fully built the PC and everything was going very well until i powered it on. all leds turned on and fans started spinning. the cpu ez debug light turns on for a few seconds and then turns off again. no other debug lights turn on. the fans go to their idle speed.the monitor however does not display anything. I have made sure the hdmi cable is plugged in to the graphics card port and not the motherboard. the monitor has power and registers that the hdmi cable is plugged in but says no signal. i have tried removing all un-needed components for boot and tried using just 1 ram stick but i have had no luck. could this be a problem with the motherboard?
If anyone has any advice or knows what going wrong please help me out.
Thanks.
Ryzen 7 2700
MSI GTX 1060 6GB
120GB kingston ssd
Thanks.
