I recently just finished building my 1st new pc with all new parts except for the hd 6670 graphics card and a 500GB HDD hard drive which had drivers from my old pc setup installed on it as well as a copy of windows 7 ultimate 64bit. After completing the build i powered up the pc and got to the msi BIOS setup. After having a read through the MSI user guide that came with it, i didnt think i needed to install anything just yet and that it could be done once i had the pc up and running, so i saved and exited the bios menu. Windows 7 loaded but just as i got to the desktop and thought i was in the clear the computer shut down, and ever since it will not boot up again.
1) when i try and turn on the computer, the fans and leds will briefly power up for less than a second then immediately power down and i have to diconnect the psu from the wall before i try again.
2) i have read posts from other threads before about following the trouble shooting steps and none of these helped me out.
3) i tried to breadboard but the computer would just do the same thing as before of power up for less than a 2nd then immediately power down.
4) tested the power supply and it ran smoothly with no loading
my system specs are:
CPU: AMD bulldozer fx6100 black edition 3.30ghz
motherboard: MSI 970A-G46
PSU: 550w CiT Black edition series power supply
RAM: 2x 4GB DDR3 exceleram white sark running at 1600
GPU: 1GB DDR3 saphire hd 6670
CASE: antec three hundred series
HARD DRIVE: 500GB hard drive with old computer compnent drivers installed and windows 7 ultimate 64bit
I have a feeling i may have fried the mother board in which case do i need to replace the cpu, ram, gpu, etc? if i havent fried the motherboard any help would be much appreciated. ty
