Question Pc problems due to EMI?
Mar 18, 2024
11
Hi! So i've had this problem for a while now but super tired of it. For some time i've had those weird pop ins and low rendered distance and shimmering and jagged edges and so on. Random stutters aswell sometimes the graphics better and sometimes worse same goes for the pop ins. The pop ins arent always in the same place thats why i wonder if it's due to emi? Could i get an good explaination on what cause emi and how to avoid it if so? Cause im interested in getting rid of it if i now have it. I've changed specs 2 times. I have also asked my friend if he have these issues and he does not. I have a 1440p monitor.
You can start by listing the make and model of all your parts.
Unless you are running a few microwaves next to you EMI shouldn't be an issue.
This sounds more like a system that's old and needs upgrades or you need to turn down your settings.
Rx 6800xt
Cpu: i5 13600k or 12600k pretty unsure rnow so sorry about. I check that later but i think 13600k
evo 870 drive
Ram 32 gb.
Mouse: SK-S ace sköll
Keyboard: Some old asus one. Pretty bad but does the job.
Some chassis i dont remember the name of.
All my systems act the same way recently btw. From ps5 that i bought last month to test if the issue went away. It actually went away for like 2-3 days until the pop ins started to exist more and more eventually.
So if i buy something completely new it randomly appears days after and it just becomes visually heartbreaking literally.
Does this sound like emi atall tbh? Cause new stuff i buy just works normally for like 2-3 days.
I will write this again just to make sure i got the most important part completely right
!Important... I bought a ps5 just to test if this issue went away (compared to my pc) And it actually went away the first 2-3 days and the issue came on ps5. Its like whatever i buy and connect from my old parts get the issue btw. Sorry for this long answer just want to make sure with everything :)
