Pc Problems PLEASE HELP - [PLEASE]
Jun 20, 2018
7
So starting about a few days ago I click my computer on and I try to play games like fornite, mc etc. Well I notice as im playing that the screen looks all choppy i went from 1000fps to 200 and just things like that. It runs slow it seems like their is a problem with the graphics but I reinstalled all the drivers cleaned pc checked temps and whatever then i finally did a pc reset and it fixed the visual chopp but it still runs slow fps and is just slow in general - please help me im getting to the point of throwing this computer outside of my window.
gtx 1050 ti 4gb superclocked
intel i5 6600
corsair vengeance 8gbram
1tb ssd
Thatvpc isnt capable of running it 1000 fps, on lowest of low possible 300, also image is looking choppy cause i guess your monitor js 60Hz and lower or higher fps than that would give you choppy image, turning on vsync would remove choppines but gives you a bit slower response time.
Disable any 3rd party anti-virus/firewall app(unless there's a Game Mode, then turn it on). Also if you're on a newer Windows 10 build, try disabling 'Game Mode': https://www.windowscentral.com/how-enable-disable-game-mode-windows-10
Other then that, open 'Task Manager' while you're playing. Check CPU/GPU/MEM/HD usage and see what's consuming what. End Task/Disable any non-windows apps that are consuming a lot of any of those.
MERGED QUESTION
Question from mason65049 : "Pc Problems PLEASE HELP - [PLEASE]"
ive got the latest drivers - no viruses - ive done everything - its like screen tearing and random fps drops. like a week ago my pc was running fine then i updated to this new windows 10 1803 and it went to shit
The whole computer is brand new last year- and the past 9 months i wasnt even using it, so when i got back it was running fine then i did the update for 1803 and it just kinda went to shit, i switched to linux for now to see if i could figure anything out from here.
