Question PC randomly freezes, sometimes buzzing sound in headphones ?
Sep 17, 2021
4
Lately my pc has been having freezes at seemingly random intervals. I game most of the time, but it's also frozen while simply browsing chrome. I don't think it's an overheating issue. I checked the temps and my gpu is fine. Cpu max is at 80C while gaming, 50C while idle, which is high, but should be ok. I've checked my RAM with the windows diagnostic and it's fine as well. There's no slowdown or anything prior to the freeze. PC is running normally, then immediately it freezes, and as mentioned there's usually a consistent buzz from the headphones. Pc noise doesn't change. I have to hard shutdown it at freeze.
Hi, did you try to reinstall the audio driver? Check in event viewer if it show something that crashed.
Do you have SSD or HDD?
I have an SSD. It's about 6 years old now. I checked it's 'health' a few months ago and it seemed to be fine. I'll try reinstalling the audio driver.
Give hardware specs, one way,
download hwinfo,
install and open it=click run,
close the top window which is the system summary,
in the main window at the left top click "save report",
at the bottom of the next window check "Summary for Clipboard",
after that you'll see what's in the pc,
copy by clicking "copy to clipboard" and rightclick+paste in your next respons
need to add for psu maker+model+wattage.
Computer: ASUS All Series
CPU: Intel Core i5-4460 (Haswell-DT Refresh, C0)
3200 MHz (32.00x100.0) @ 3200 MHz (32.00x100.0)
Motherboard: ASUS B85M-E
BIOS: 2001, 06/16/2014
Chipset: Intel B85 (Lynx Point)
Memory: 8192 MBytes @ 800 MHz, 10-10-10-30
- 4096 MB PC12800 DDR3 SDRAM - Kingston KHX1600C10D3/8G
Graphics: XFX RX 570
AMD Radeon RX 570, 8192 MB GDDR5 SDRAM
Drive: ST1000DM003-1CH162, 976.8 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: KINGSTON SH103S3240G, 234.4 GB, Serial ATA 6Gb/s @ 6Gb/s
Sound: Intel Lynx Point PCH - High Definition Audio Controller [C2]
Sound: ATI/AMD Bermuda/Ellesmere - High Definition Audio Controller
Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
Network: Intel PRO/1000 GT Desktop Adapter
OS: Microsoft Windows 10 Professional (x64) Build 19042.1165 (20H2)
Psu is corsair rm850
