Hello all,
First of all I am new to building a pc and this forum so please forgive me if I post this in the wrong place.
I am from Germany so my english wont be perfect here and there. Sorry for that.
Yesterday I build my new system with the following components:
Ryzen 5 3600
AsRock Fatal1ty B450 itx/AC
ZOTAC GTX 1660 Super Amp edition
16GB Corsair Vengeance LPX LP DDR4 3200
For Power I have an Cooler Master B700 V2 which did its Job without any issues for about a year in my old system
Also I use a Samsung EVO 500GB SSD which also woked in my old system.
I think this ist everything that ist relevant if I forgot sth please tell me and I will provide the information.
But what is my Problem now?
I tested the system and bootet from the old windows Installation that was still on the SSD. It all seemed to work so I tried to restart after about 2 minutes
The following Installation of Windows 10 via USB went trough without any Problems and after some time in the freshly installed OS the Screen Just went black and the system restarted. Now I am Not even able to Install from USB anymore without having the system restarting randomly.
What I tried so far:
Check all connectors
CPU temperature is at about 50°C
Started the Installer in UEFI and Legacy Mode
Tried to install latest debian(also failed)
Mobo is at latest firmware
Adjusting ram settings in UEFI setup from Auto to the explicit values
Tried to Install on another known good HDD (but 10TB dont know if this size will cause new problems)
I ran memtest86 (booted from USB) over night which told me no error with ram and also it seemed to have stayed on over night.
Also in UEFI setup I left it at idle to See if it will restart.
What I want to test later in the evening:
Perform a Stress Test of the system via ultimate boot cd and See if load causes the system to reboot and at the same time measure the power consumption.
But apart from that I dont know what can cause the Problems (maybe psu even if it never caused Problems -> stresstest?)
What can I do to identify the problem?
Did you experience issues like this and have any ideas where this random reboot comes from?
I would appreciate any hint/Input from you.
Best regards and thanks in advance
Tim
Ps: I know there are no random restarts. What I mean with random in this case ist that I cant find any obvious reason for restarting like "If at some Point in Installation then restart"
Ryzen 5 3600
Tim
