Hi, after I enterd a CS:GO game my pc starts to reboot immediately, the same hapends if I open a gpu benchmark, but if I open a cpu benchmark it works fine.
CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.1.0
Monitoring
Mainboard Model 970 Pro3 R2.0 (0x00000326 - 0x577E89F0)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6776
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xC3
LPCIO Revision ID 0x33
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF F8 CE 00 00 FF FF
20 C3 33 FF 00 5C 00 00 80 00 FF 60 04 81 00 00 01
30 E1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Nuvoton NCT6776
Voltage 0 1.30 Volts [0xA3] (CPU VCORE)
Voltage 1 1.78 Volts [0xDF] (VIN1)
Voltage 2 3.22 Volts [0xC9] (AVCC)
Voltage 3 3.20 Volts [0xC8] (3VCC)
Voltage 5 1.69 Volts [0xD3] (VIN5)
Temperature 0 41 degC (105 degF) [0x29] (SYSTIN)
Temperature 1 69 degC (156 degF) [0x8A] (CPUTIN)
Temperature 3 40 degC (104 degF) [0x28] (TMPIN3)
Fan 0 1066 RPM [0x42A] (SYSFANIN)
Fan 1 5818 RPM [0x16BA] (CPUFANIN)
Hardware registers
bank 0
00 04 FF 04 FF 00 FF FF FF FF FF FF FF FF FF FF FF
10 04 FF 00 00 00 00 FF FF 40 00 00 00 00 00 00 00
20 A4 DF C8 C8 FF D3 FF 28 FF FF FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
40 03 00 50 FF FF 00 3F FF 2D FF FF FF 18 05 00 A3
50 FF FF FF FF FF FF FF FF C1 FF FF FF FF 00 00 FF
60 00 FF FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 28 80 45 80 C1 80 FF FF FF FF FF FF FF
80 FF 03 1F 0F FF 3C 3C 3C 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 0A 0A 0A 0A AA EF 80 FF 40 46 C4
A0 0E 01 00 00 FF 00 00 FF 00 00 80 66 66 06 00 01
B0 00 00 00 00 00 00 34 00 1C 00 00 01 C0 80 C4 FF
C0 01 00 00 00 00 00 00 00 00 03 02 FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 1
50 45 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 2
50 C1 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
bank 3
bank 4
50 00 13 FF FF 00 00 00 FF 00 DE 1F B1 09 FF FF FF
bank 5
50 D8 00 00 FF 00 00 00 00 FF FF FF FF FF FF FF FF
Hardware monitor D3D
Hardware monitor AMD ADL
Voltage 0 1.00 Volts [0x3E8] (GPU)
Power 0 21.15 W (GPU)
Temperature 0 63 degC (145 degF) [0x3F] (GPU)
Fan 0 726 RPM [0x2D6] (GPU #0)
Clock Speed 0 301.34 MHz [0x12D] (Graphics)
Clock Speed 1 2000.00 MHz [0x7D0] (Memory)
Clock Speed 2 n.a. (Processor)
Processors
Number of sockets 1
Number of threads 8
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 1)
-- Thread 1 1
-- Core 2 (ID 2)
-- Thread 2 2
-- Core 3 (ID 3)
-- Thread 3 3
-- Core 4 (ID 4)
-- Thread 4 4
-- Core 5 (ID 5)
-- Thread 5 5
-- Core 6 (ID 6)
-- Thread 6 6
-- Core 7 (ID 7)
-- Thread 7 7
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 8 (max 8)
Number of threads 8 (max 8)
Manufacturer AuthenticAMD
Name AMD FX-8350
Codename Vishera
Specification AMD FX(tm)-8350 Eight-Core Processor
Package Socket AM3+ (942)
CPUID F.2.0
Extended CPUID 15.2
Core Stepping OR-C0
Technology 32 nm
TDP Limit 125.2 Watts
Core Speed 3991.2 MHz
Multiplier x Bus Speed 20.0 x 199.6 MHz
Base frequency (cores) 199.6 MHz
Base frequency (ext.) 199.6 MHz
Rated Bus speed 2394.7 MHz
Stock frequency 4000 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
Microcode Revision 0x6000852
L1 Data cache 8 x 16 KBytes, 4-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size
L3 cache 8 MBytes, 64-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Eh
Cache descriptor Level 1, D, 16 KB, 1 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 8 thread(s)
FID/VID Control yes
Min FID 7.0x
# of P-States 7
P-State FID 0x1A - VID 0x0A - IDD 13 (21.00x - 1.425 V)
P-State FID 0x19 - VID 0x0D - IDD 13 (20.50x - 1.387 V)
P-State FID 0x18 - VID 0x13 - IDD 12 (20.00x - 1.313 V)
P-State FID 0x12 - VID 0x1B - IDD 10 (17.00x - 1.212 V)
P-State FID 0xC - VID 0x23 - IDD 8 (14.00x - 1.112 V)
P-State FID 0x5 - VID 0x2C - IDD 5 (10.50x - 1.000 V)
P-State FID 0x10C - VID 0x36 - IDD 4 (7.00x - 0.875 V)
PStateReg 0x80000186-0x0000141A
PStateReg 0x80000186-0x00001A19
PStateReg 0x80000177-0x00002618
PStateReg 0x8000015F-0x00003612
PStateReg 0x8000014B-0x0000460C
PStateReg 0x80000136-0x00005805
PStateReg 0x80000124-0x00006C4C
PStateReg 0x00000000-0x00000000
Package Type 0x1
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Base TDP 6 Watts
Boosted P-States 2
Max non-turbo ratio 20.00x
Max turbo ratio 21.00x
Attached device PCI device at bus 0, device 24, function 0
100 00000000 00000000 00000000 00000000
110 00000000 00000000 00000000 00000000
120 00000000 00000000 00000000 00000000
130 000000C1 00000000 00000000 00000000
140 00000000 00000000 00000000 00000000
150 00073900 00000000 00000000 00000000
160 00000000 00000000 00000400 0066E066
170 00000109 00000000 00000000 00000000
180 00000000 00000000 00000000 00000000
190 00000000 00000000 00000000 00000000
1A0 80000003 00000000 00000000 00000000
1B0 00000000 00000000 00000000 00000000
1C0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 000000FE
1E0 00000000 00000000 00000000 00000000
1F0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 1
120 00000000 00000047 00000000 00000000
130 00000000 00000000 00000000 00000000
150 00000000 00000000 00000000 00000000
160 00000000 00000000 00000000 00000000
170 00000000 00000000 00000000 00000000
1A0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 2
100 00000000 00003448 00000000 00000000
110 000001C4 00000000 0440A424 0CE00F41
120 008CB1DB 00000000 00000000 00000000
130 BCF0E37F A10DD73B 4779BE77 663BF7CC
140 00000001 00000000 00000000 00000000
160 00F83FE0 00000000 00000000 00000000
170 00000000 00000000 00020000 00000000
180 0000000A 00800004 3D000000 00020000
190 0B010000 0F480892 8D0F4007 00000000
1A0 031D0220 00000000 00000000 00000000
1B0 0FC39001 480F7D26 00000000 00000000
Attached device PCI device at bus 0, device 24, function 3
140 00A11755 00000055 0000C12A 00000000
160 C0000000 00000000 C0000000 00000000
170 C0000000 00000000 00000000 00000009
180 017003E3 00000000 08000210 00000008
190 00000000 00000000 00780400 00000000
1A0 00034104 00000000 00000000 00000000
1B0 03F5B827 00000000 00141000 00000000
1C0 00000000 0003CCCC 00000000 00000100
1D0 00000000 00000000 002B170F 00000000
1E0 00000000 80001387 00000000 00000000
1F0 00080000 00000000 00000000 004C074F
Attached device PCI device at bus 0, device 24, function 4
100 00000000 00000321 00000000 00C401EB
110 000FE001 00000000 0007000B 00000000
120 00000000 00000000 00000500 00000000
140 1059C9AF 000002CB 26AF0CF7 0000081F
150 00000C6A 00F5D1C4 00000000 00000008
160 00600F20 00000003 00000000 00000457
180 E000530F 00001004 00000000 00000000
1A0 00000017 00000000 00000000 00000000
1B0 00000000 00000000 001C0207 00000000
1C0 00000000 00000110 00000360 00000090
1D0 00080000 0000FFFF 00000000 00000000
1E0 0B0C141A 0B0C1A19 0AEE2618 0ABE3612
1F0 0A96460C 0A6C5805 0A486C4C 00000000
Attached device PCI device at bus 0, device 24, function 5
120 00001111 80000000 00009136 00000000
160 00007C0F 00000000 00000000 00000000
170 00000808 0001F038 00000000 00000000
190 2233457A 0000000B 00202020 00000000
Temperature 0 54 degC (128 degF) (Package)
Temperature 1 54 degC (128 degF) (Cores)
Clock Speed 0 3991.19 MHz (Core #0)
Clock Speed 1 3991.19 MHz (Core #1)
Clock Speed 2 3991.19 MHz (Core #2)
Clock Speed 3 3991.19 MHz (Core #3)
Clock Speed 4 3991.19 MHz (Core #4)
Clock Speed 5 3991.19 MHz (Core #5)
Clock Speed 6 3991.19 MHz (Core #6)
Clock Speed 7 3991.19 MHz (Core #7)
Core 0 max ratio 21.0 (effective 20.0)
Core 1 max ratio 21.0 (effective 20.0)
Core 2 max ratio 21.0 (effective 20.0)
Core 3 max ratio 21.0 (effective 20.0)
Core 4 max ratio 21.0 (effective 20.0)
Core 5 max ratio 21.0 (effective 20.0)
Core 6 max ratio 21.0 (effective 20.0)
Core 7 max ratio 21.0 (effective 20.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00600F20 0x00080800 0x3E98320B 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x00000006 0x00000000 0x00000000 0x00000001 0x00000000
0x00000007 0x00000000 0x00000008 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x000003C0 0x40000000
0x0000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x80000000 0x8000001E 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00600F20 0x10000000 0x01EB3FFF 0x2FD3FBFF
0x80000002 0x20444D41 0x74285846 0x382D296D 0x20303533
0x80000003 0x68676945 0x6F432D74 0x50206572 0x65636F72
0x80000004 0x726F7373 0x20202020 0x20202020 0x00202020
0x80000005 0xFF40FF18 0xFF40FF30 0x10040140 0x40020140
0x80000006 0x64006400 0x64004200 0x08008140 0x0040C140
0x80000007 0x00000000 0x00000000 0x00000000 0x000007D9
0x80000008 0x00003030 0x00001000 0x00004007 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00010000 0x00000000 0x00001CFF
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF040F018 0x64006400 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000
0x8000001C 0x00000000 0x80032013 0x00010200 0x8000000F
0x8000001D 0x00000121 0x00C0003F 0x0000003F 0x00000000
0x8000001D 0x00004122 0x0040003F 0x000001FF 0x00000000
0x8000001D 0x00004143 0x03C0003F 0x000007FF 0x00000001
0x8000001D 0x0001C163 0x0FC0003F 0x000007FF 0x00000001
0x8000001E 0x00000010 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000008
MSR 0xC0010061 0x00000000 0x00000040
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010064 0x80000186 0x0000141A
MSR 0xC0010065 0x80000186 0x00001A19
MSR 0xC0010066 0x80000177 0x00002618
MSR 0xC0010067 0x8000015F 0x00003612
MSR 0xC0010068 0x8000014B 0x0000460C
MSR 0xC0010058 0x00000000 0xE0000021
MSR 0xC0010015 0x00000000 0x09000011
MSR 0xC001001F 0x00404000 0x00810008
MSR 0xC0010071 0x02800006 0x3E022618
MSR 0xC0010070 0x00000000 0x3E022618
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x00600F20 0x01080800 0x3E98320B 0x178BFBFF
0x80000001 0x00600F20 0x10000000 0x01EBBFFF 0x2FD3FBFF
0x8000001E 0x00000011 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00800
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x00600F20 0x02080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000012 0x00000101 0x00000000 0x00000000
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
CPUID
0x00000001 0x00600F20 0x03080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000013 0x00000101 0x00000000 0x00000000
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 4, Thread ID 0
CPUID
0x00000001 0x00600F20 0x04080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000014 0x00000102 0x00000000 0x00000000
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 5, Thread ID 0
CPUID
0x00000001 0x00600F20 0x05080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000015 0x00000102 0x00000000 0x00000000
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 6, Thread ID 0
CPUID
0x00000001 0x00600F20 0x06080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000016 0x00000103 0x00000000 0x00000000
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 7, Thread ID 0
CPUID
0x00000001 0x00600F20 0x07080800 0x3E98320B 0x178BFBFF
0x8000001E 0x00000017 0x00000103 0x00000000 0x00000000
Storage
Drive 0
Name SPCC Solid State Disk
Revision SBFM61.3
Serial BB2A07930E5300164055
Capacity 238.5 GB
Type Fixed, SSD
Bus Type ATA (3)
Features SMART, TRIM
Volume c:\, 238.5 GBytes (34.9 percent available)
Drive 1
Name HITACHI HUA721010KLA330
Revision GKAOA90A
Serial PAKVZTBF
Capacity 931.5 GB
Type Fixed
Bus Type ATA (3)
Features SMART
Volume d:\, 488.3 GBytes (22.4 percent available)
Volume e:\, 443.2 GBytes (46.7 percent available)
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC084
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x0C45, product=0x7603
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0x0A4D
Graphic APIs
API D3D
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
ID 0x2140001
Name Radeon (TM) RX 480 Graphics
Board Manufacturer ATI Technologies
Codename Polaris
Technology 14 nm
Memory size 8 GB
Memory type GDDR5
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1002)
Model ID 0x67DF (0x0B37)
Revision ID 0xC7
Performance Level 0
Performance Level 1
Monitor 0
Model LG ULTRAWIDE (LG Electronics (GoldStar))
ID GSM59F1
Serial
Manufacturing Date Week 12, Year 2017
Size 28.6 inches
Max Resolution 2560 x 1080 @ 59 Hz
Horizontal Freq. Range 30-90 kHz
Vertical Freq. Range 56-75 Hz
Max Pixel Clock 240 MHz
Gamma Factor 2.2
Monitor 1
Model ASUS VP247 ()
ID ACI24C7
Serial FALMTF081175
Manufacturing Date Week 42, Year 2015
Size 23.4 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 24-83 kHz
Vertical Freq. Range 50-75 Hz
Max Pixel Clock 170 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
Binaries
Monitoring
LPCIO
LPCIO Model NCT6776
LPCIO Chip ID 0xC3
Config Mode LDN 0xB
Hardware Monitors
Hardware registers
bank 0
bank 1
bank 2
bank 3
bank 4
bank 5
Processors
Number of sockets 1
Number of threads 8
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 1)
-- Thread 1 1
-- Core 2 (ID 2)
-- Thread 2 2
-- Core 3 (ID 3)
-- Thread 3 3
-- Core 4 (ID 4)
-- Thread 4 4
-- Core 5 (ID 5)
-- Thread 5 5
-- Core 6 (ID 6)
-- Thread 6 6
-- Core 7 (ID 7)
-- Thread 7 7
Timers
Sys timer 1.000 KHz
Socket 1 ID = 0
Name AMD FX-8350
Codename Vishera
CPUID F.2.0
Extended CPUID 15.2
Core Stepping OR-C0
Technology 32 nm
FID/VID Control yes
Min FID 7.0x
# of P-States 7
Package Type 0x1
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Base TDP 6 Watts
Boosted P-States 2
Thread dumps
CPU Thread 0
APIC ID 0
CPUID
CPU Thread 1
APIC ID 1
CPUID
CPU Thread 2
APIC ID 2
CPUID
CPU Thread 3
APIC ID 3
CPUID
CPU Thread 4
APIC ID 4
CPUID
CPU Thread 5
APIC ID 5
CPUID
CPU Thread 6
APIC ID 6
CPUID
CPU Thread 7
APIC ID 7
CPUID
Storage
Drive 0
Revision SBFM61.3
Capacity 238.5 GB
Type Fixed, SSD
Bus Type ATA (3)
Drive 1
Revision GKAOA90A
Serial PAKVZTBF
Capacity 931.5 GB
Type Fixed
Bus Type ATA (3)
Features SMART
USB Devices
Graphic APIs
API D3D
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
ID 0x2140001
Codename Polaris
Technology 14 nm
Memory size 8 GB
Memory type GDDR5
Revision ID 0xC7
Performance Level 0
Performance Level 1
Monitor 0
ID GSM59F1
Serial
Size 28.6 inches
Gamma Factor 2.2
Monitor 1
Model ASUS VP247 ()
ID ACI24C7
Serial FALMTF081175
Size 23.4 inches
Gamma Factor 2.2
ACPI
ACPI Tree
