PC reboots randomly, PSU problem?
peppone
14
My computer reboot randomly without blue screen.
I switched OS (from windows to linux) same problem, so i don't think it's a software issue.
I tested all my hardware:
Ram > memtest86
Other components tested with glrm Linux distro and everything seems to be good.
I started thinking that my PSU is not enough for my configuration:
PSU 500W standard (don't remember the brand sorry)
RAM 3072 MB DDR2, 667 MHz, (PC2-5300)
EVGA 9800GTX+ 512Mb
Asus M4A78-E Mobo
320Gb WD HDD + a couple of external FireWire 80Gb HDD
What do you guys think? It's a PSU problem?
If yes what PSU do you reccommend? How many Ampere do I have to supply?
Thanks in advance
peppone
14
Ok here are more detailed specs:
PSU
ORION 585d
DC output +3.3V +5V +12V1 +12V2 -12V +5Vsb - Max.A 36A 36A 19A 20A 1A 2A
CPU
AMD Athlon™ 64 X2 6000+, 64-bit dual core processor
MoBo
Asus M4A78-E
Video Card
EVGA 9800GTX+ 512Mb
RAM
3072 MB DDR2, 667 MHz, (PC2-5300) dual channel memory (two 1024 MB + two 512 MB modules)
HDD
320 GB, 7200 RPM, SATA II hard drive
Optical Drive
18X DVD ±RW super multi-format dual layer drive with LabelFlash™ support (up to 8.5 GB)
Card Reader
15-in-1 high speed digital media manager with Smart Copy button
Network
Atheros L1E Gigabit LAN Controller
I already checked my CPU voltage and temp, everything seems to be normal... Core1 aprox 23°C Core2 aprox 24°C
peppone
14
Yes, i forgot to say that i tried to flash my BIOS with a newer version to solve this problem, and all the settings are "Default".
Thanks for helping me with this guys, i really appreciate.
You need a better PSU. What you have is an obsolete design (no APFC, switchable voltage, really heavy 3.3 volt and 5 volt rail, and relatively light 12 volt rails) dressed up with modern cables.
If the "reboots randomly" means under a heavy graphics load, you definitely need a better PSU. A good 500 - 550 watt PSU would do.
For something like this, I'd put in a Corsair 550VX (41 amp 12 volt rail)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
