PC Recently shutting down due to power surges
Rex_Za_Fox
Commendable
Oct 6, 2016
22
So, lately my computer has been shutting down due to the detection of power surges (3 times in the last week), I suspect that it might be because of my psu but I can't be sure so here are my specs.
Motherboard: H81M-E
https://www.asus.com/Motherboards/H81ME/
Graphics Card: MSI armour GTX 960
https://www.msi.com/Graphics-card/GTX-960-2GD5T-OC.html#hero-overview
CPU: Intel I7-4790K at 4.2Ghz
http://ark.intel.com/products/80807/Intel-Core-i7-4790K-Processor-8M-Cache-up-to-4_40-GHz
Ram: 12 GB
3x HHD'S ( I also believe all the HDD's might be part of the problem)
1x SSD
PSU: Nox Urano SX 500Watts
http://www.nox-xtreme.com/en/product/urano-sx-500w/54/
Also... I'll attach a print screen of HWM monitor's indications on all the hardware
PS: Why does it look like my cpu is always at 100% of usage? Clock speed wise
Thank you in advance
How could I fix it?
I have the option to remove one of the HDD's if necessary.
from the left image, the voltages readings form the mainboard, 2 are low, 3.3 and 12v, are very low
do you have a ups?
can you test a new psu, also try to run your pc on a ups, so you avoid surprise power loses to really detect any psu problem and not sudden power loses or spikes causing sudden restarts or shutdowns
My first suspicion would be your psu as well. Don't wait until it kills your components to try to replace it. I don't know if you have warranty on yours or not, but here's a nice list if you're looking for replacement:
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
That being said, I once lived in an old house with a very bad wiring, and constant power surges. A surge protector should be must on any computer, at the very least as it costs very little, and without it, you can end up replacing your whole rig.
Surge protector won't save you from a bad psu though, so i would still check yours by a professional, or just try another one from a different computer, to see if you're getting the same thing (provided wattage is sufficient).
I do not have a ups and I do not have any other psu's to swap out and test again.
Yeah thank you... I wish to not have the need to replace it since as of now I don't have much money for an upgrade.
And I never had problems like these... Until I added a new HDD... Not sure if that might be the issue.
If you PSU is not great quality, adding additional load, even a small one like hdd can make it unstable. Get someone to check your psu for you. Also, get a surge protector in case it's your in-house wiring. If you're not high on money at the moment, do not use your rig. Continued use with these signs can result in a power surge that may fry your rig completely, your shiny expensive cpu, gpu and motherboard. Don't risk it, it'll cost you way more than psu or surge protector alone.
this is not a upgrade, this would be a necessity, lower voltages can end up damaging the mainboard and also will not let you play games really, once load is applied the gpu will not deliver and can cause restarts, not to mention the psu itself just dying and leaving you with a black screen, untill you get the new psu, hopefully just the psu
is a new psu? old without warranty?
I'm running a cpu stress test to check on the voltages... the psu is around 1 maybe 2 years old, I can't know for sure.
i don't know of any 7500 watts psu, max i have hears is 1500 or 2000 watts psu and that is around 4 times what most people needs
for your parts, you can do well with a 550 watts psu and there will be plenty of power
try to find one modular, installing one is so simple, you just use the cables you need, don't need to hide the ones you don use behind the mainboard
I meant 750... sorry about that.
You can't really trust software readings for voltages. They're actually not even read from the PSU they're read from the CPU VRM somewhere, it's not really accurate ever and I've often see numbers so far off. For your parts, all you need is a decent 450W PSU. Anything more is going to be overkill and unnecessarily spending more money than you need.
Sometimes Asus anti-surge has been known to go off over faulty readings, some people have disabled it in the BIOS and had no problems. But NOX PSUs are indeed stinky.
Do you think I should NOT run my computer with voltages like the ones in the pictures?
No you think it's safe to run the computer as it sits?
All the voltages in the image are within the ATX specification. But like I said, voltage readings from software aren't inaccurate. The only way to really know the voltage is with a digital multimeter device.
Something that I do not own... If I buy a better psu, it should all be fixed right?
Yes I'm quite confident it'll be fixed. And if it still shows the surge message I would just disable the anti-surge thing in the BIOS and be done with it.
My issue is just that I'm afraid that it might damage my pc.
yes, often those readings are not perfect, but usually when you see bad readings both the psu and mainboard are in trouble, i have seen both, psus doing that and mainboards with psus doing the problem, the psu change doesn't help, sometimes mainboard does keep delivering bad readings, but when i have seen it, always a bad psu was involved
That is always a toss up. IF the power supply goes down it could take out other components. If you are going to buy one soon I wouldn't worry to much as long as you don't load up your PC and cause it to crash more. You have to remember the PSU in a computer is the most important bar none.
