PC Restarts Repeatedly and No Post
haashim
48
Sorry if wrong category.
My PC worked for about a week but then one day it decided to restart repeatedly and there is no post.
But when I remove 2 sticks of any ram module (64GB Kingston HyperX Beast 2133MHz) It doesnt restart repeatedly but there is no signal to my monitor, I have given my GPU (GTX Titan) in for testing and the company (scan.co.uk) said they tested it and it was fine.
Any help?
Did you build the PC yourself? If it isn't doing anything and there is no visual then it might prossibly be the motherboard PCI slot dead or the motherboard itself. Can I have some specs of your PC?
Yes i built it myself and PC SPECS:
M/B : MSI Big Bang Xpower 2
RAM: 64GB Kingston HyperX Beast 2133MHz
GPU: GTX TITAN
PSU: Corsair AX1200i
Anything else just ask.
It might be the motherboard being an issue. It might be looping and trying to post, but something is preventing it in the motherboard. That's my suggestion. It might be the motherboard itself.
The pc is no longer rebooting repeatedly however there is nothing coming up on my monitor
That is with your ram out? I believe it would still be the motherboard. My old one wouldn't display anything and sure enough it was dead. Its weird if the ram is causing it tho if that is the case.
This is with two ram sticks out, but how can it be my motherboard if the leds are on?
It supports up to 128GB and has 8 Slots.
Would it be fine if I use a psu that has a lower voltage than my pc is recommended to have, just to see if the psu is the problem? Or would that even be possible?
what do you mean by intel speed step technology, how do i stop it?
