PC Restarts Repeatedly and No Post
haashim
48
Sorry if wrong category.
My PC worked for about a week but then one day it decided to restart repeatedly and there is no post.
But when I remove 2 sticks of any ram module (64GB Kingston HyperX Beast 2133MHz) It doesnt restart repeatedly but there is no signal to my monitor, I have given my GPU (GTX Titan) in for testing and the company (scan.co.uk) said they tested it and it was fine.
Any help?
Maybe when they tested it, your pc didnt restart repeatedly. I think it's a hardware problem. Or maybe the video card? Have you went to a tech to let them check it for maybe 2 days? I think that will help
Rebooting can be caused by almost any component, need to test things one at a time and see what causes it. Does it work OK without the video card or does the same thing? If it reboots even without the card, it's not the card. Try different RAM sticks, one at a time. Could be the power supply also or the motherboard but RAM and video card are easy to test without actually swapping out components.
I have taken out two ram modules and my pc is not rebooting. However, nothing is showing up on my monitor. I have cleared cmos aswell.
