Question PC says "No Audio Output device is installed" ?
Nexver
This morning, my PC started up without playing any audio and showing 'No Audio Output Device in installed' with a red cross in the volume section. I have uninstalled and re installed the audio drivers, disabled and re-enabled them. I have also restarted the windows audio service. But nothing has worked.
Here is the link for my device manager screenshot.
My motherboard is Gigabyte GA-AB350M-Gaming 3 and OS is Windows 10.
Nexver
Right click on the speaker icon down by the time in the system tray and click on Open Sound Setting.
Make sure your chosen Output Device matches what you are using for your speaker connection and that your volume is up and not muted.
That is the problem. It does not show any device (it previously showed realtek digital output).
You can see it here.
