Hi everyone,
My uncle gave me a PC to fix,it seems to power up,but it doesn't do anything else.
It won't start the loading from HDD and i get no signal on the screen,the power led is on and PSU/CPU fan are running,the HDD led blink for half second right when i push the power button (seems more a power check to me) then the HDD led turn off.
What i tried to do so far:
-Removed RAM,reinstalled it/switched slot;
-Removed Mobo battery/plugged in a new one;
-Used another compatible PSU;
-Tried to remove every PCI card [but it has a build-in VGA];
-Tried to remove RAM/Battery/HDD etc in order to receive any audio signal [beep] from the mobo but nothing.
-Tried to touch the CPU heatsink (with the fan off,but the heatsink was still there) for any sign of heating but after 30 secs it was still metal-cold (i also mesured the heating with a termometer,it starts from 20°C and gain 1°C every 45 seconds,i switched it off at 23°C);
What else can i try to do?
I'm thinking of a mobo fault but i don't know how to better verify this assumption.
NOTE: i don't have a temporary compatible mobo to test the CPU every component.
Thanks in advance.
Thanks in advance.
