Question PC shut off and no power signal on system
darkknightrasil
84
Computer just shut off. There is no power showing on pc. Not sure what it is, I plan to look at it when I wake up later. Not sure if I smell any burning but there is heat I can feel coming from the fan port. Typically my pc runs perfect. I’ll post specs and pictures later. I checked surge protector and it’s good. This is the first time it’s have ever had a problem and I built it 2 years ago with all new hardware.
darkknightrasil
84
these are the specs for my pc. It’s 2 years old minus the psu/gpu I upgraded in may when I bought a 3080 and needed a psu with more ports for 3 power cords on gpu.
The old psu was a “seagate gold 750.”
I had no issues at all until this happened at 1am. For the past 8 days I have had power outages which is what I am thinking could be the issue. Overall my electricity cut off 10+ times (darn California electrical grid). Not in this specific moment though at 2:20am it just shut off without a notice. Unplugged pc for 10 minutes then tried to flip that switch on psu and a quick blue flash popped up unless my eyes played a trick on me.
I’ll post pictures in a moment
SPECS:
Motherboard: ASUS ROG Maximus XII Hero Z490 (WiFi 6) LGA 1200 (Intel 10th Gen) ATX Gaming Motherboard, 14+2 Power Stages, DDR4 4800+, 5Gbps LAN, Intel LAN
CPU Cooler: be quiet! Dark Rock Pro 4, BK022, 250W TDP, CPU Cooler
CPU: Intel Core i9-10900K Desktop Processor 10 Cores up to 5.3 GHz Unlocked LGA1200 (Intel 400 Series Chipset) 125W
PSU:Corsair RMX Series (2021), RM1000x, 1000 Watt, Gold, Fully Modular Power Supply
RAM: Corsair Vengeance RGB Pro 32GB (2x16GB) DDR4 3200 (PC4-25600) C16 Desktop Memory - Black
GPU: 3080 ROG Strix
Case Fans: Cooler Master MasterFan MF120 Halo 3in1 Duo-Ring ARGB 3-Pin LightingFan, 24 Independently LEDS, 120mm Fan, PWM Static Pressure Fan, Absorbing Pads for Computer Case & Liquid Radiator
Case Fans #2: 2 LED fans in front of the tower as well
Case: Thermaltake View 71 TG (Tempered Glass) RGB Plus PC-Case - Black
Hard Drives: (4 HD drives), 1 SSD, 1 SSD m.2 NVMe
Reactions: Dark Lord of Tech
darkknightrasil
84
Tried plugging into the wall to see if it was surge protector but still no power. Unplugged gpu and removed the psu light cord as well to limit power usage. I can only assume it’s the psu? Not sure.
