PC shuts down, power button blinks blue, and wont turn on
SPECS:
Motherboard - MSI A88X-G45
GPU - AMD RX590 fatboy edition
CPU - AMD A8 - 8000
RAM - 2x 4GB Corsair Vengeance
PSU - Thermaltake TR2 600NL2NC
During mid game, my pc shuts down and I assume it over heated. The case’s power button led was blinking blue, the same itd be when I put it in sleep mode. I try to power it on, no use. I decided to take it apart and use that time to also clean it. I cracked open the PSU and found a bunch of dust, and that may be one of the problems. I cleaned everything else out, and put it back together.
So, the power button on the MB has a light and it turns on after powering on the PSU. But when I do power on the PSU, there is also 2 LEDs, one red and one blue that both turn on and flash off. Those two LEDs also flash when I turn off the PSU. When i try powering it with the case button, the 2 red leds on the gpu near the PCIE ports flash on. I tried pulling off the GPU and powering it on with the case, but some LEDs on the MB below the peripherals connector flash. I have tried 1 stick of ram and 0 stick of ram, both no use. I will try to find a PSU during the time to try and use it to power my PC, but do you guys know any other possibility as to why this might happen?
SPECS:
CPU - AMD A8 - 8000
