Question PC shuts down randomly with strange noise
Nov 18, 2020
Hey guys, I really need help with this.
These are my Specs:
CPU: AMD Ryzen 3 1300X
GPU: Geforce GTX 1060 GGB
Motherboard: AsRock A320m Pro4
RAM: 16GB
PSU: Corsair VS650 (New)
OS: Windows 10
The PC shuts down completely random. At first I thought it just happens in Videogames, but it also shuts down if I do absolutely nothing.
After it shuts down, all fans are running and I feel the PSU and the hard drives vibrating. The monitor is black, as if the PC shut down. I also hear a "clicking" noise, I can't really describe it, but I took a video:
https://streamable.com/qn9gaa
I already replaced the PSU with my last money because I thought that would be it.
It wasn't.
Now I'm stuck in homeoffice with an unreliable PC and no more money for fixing any other part. But I would really love to know what the hell is broken in this thing? Does anybody of you know?
Thanks for you help, I appreaciate it!
Ralston18
Look in Reliability History and Event Viewer for any error codes and warnings that correspond with the PC shutdowns.,
After a successful boot immediately open either Task Manager or Resource Monitor to observe system performance.
Use both but only one at at time.
Next:
Shutdown, unplug, open the case.
Clean out dust and debris.
Ensure that all cards, cables, RAM, and jumpers are fully and firmly in place.
Nov 18, 2020
Next:
The problem with the Reliability History and Event Viewer is, that I have to force shutdown the PC after it turns itself off before I can turn it on again. So only the force shutdown appears in the Event Viewer.
I checked every card, cable, RAM and jumper - everything is in place.
I run HWInfo64 and check the temperatures regularly, but nothing seems to overheat. If the PC crashes while HWInfo runs, I will check and post the log.
Nov 18, 2020
Little push, still need help. For anyone who watched the video: Is there anyone who recognizes the sound my PC makes? Btw this is recorded afterwards the PC shut down. It seems that almost anything is still running but I hear this sound. And of Course the screen is black.
