pc shuts off then power led flashes
Zumbuh
6
I recently got a new PC (about a month ago), I had some motherboard issue and I replaced it. Didn't have enough case fan headers so I bought an adapter to extend them. Not sure if it's related to my issue I am just giving context in case it's a problem. I play a lot of Rust, and I do a lot of video editing. and if you play Rust aswell you'll know that you spend hours upon hours in that game. Same with editing. Well about 3 times this month my PC has shut down and the power button would flicker. I always assumed I hit the cord or something and it got loose as I've done that before on my old pc, but it seems that is not the case. Not only today has it started to do it not in-game or in After Effects- but it has done it 7 times today. It will shut down and the power led will flicker. I am sometimes just in chrome doing absolutely nothing. I would really appreciate some help here because I just got this PC and it's really aggravating. Temperatures seem fine aswell, my CPU & GPU are both usually 50 and 60 C under load respectively.
specs:
AMD FX-8350 (yes the fx 8350, i got a really good deal don't judge lol)
AMD Wraith Cooler
XFX R9 390
MSI 760GMA-P34 Motherboard
8GB of Corsair Vengeance RAM
3TB HDD
240GB SSD
Corsair Carbide 100R
Corsair CX750M
Your power supply is failing.
The Corsair CX series is an OEM version, barely able to get the job done, and sub-par components.
Many power supplies have the internal ability to shut down instead of destroying hardware in the computer.
After writing the above I went to jonnyguru, and he said do not purchase this power supply. A cherry picked unit from the factory was sent to him and - here are the results:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=416
I suppose I will have to contact Newegg about a refund.
