Hi the problem is my pc just shuts off randomly sometimes after a couple of mins, at first i thought one of my ssd was failing so i installed another ssd and installed windows 10 but the problem still persisted for me it just shuts off with no warning and when it does run its so laggy its like running a windows 95 machine. I have tried running from different plug sockets,different cables,resitting parts,rewiring cables , running on bare components etc and could not work it out. Now i went into my bios today and all my 4 cores was showing at 95+ temperature and this pc had only been on a few seconds also when i touched my H100 heat sink it was so hot i almost burnt my hand so do you think this is why my pc keeps shutting down/failing to boot because its overheating? Should i replace the thermal compound or buy a different cpu fan or could it be the psu? The machine is about 5 years old. Thanks any help would be great i plan on going to the shop tomorrow for parts
Specs
Core i7 2600k - CPU
Corsair H100 - CPU FAN
corsair 32gb ddr3 - RAM
G1.Sniper 3 - MOBO
corsair ax1200 - PSU
corsair force gt SSD x3
Specs
Core i7 2600k - CPU
G1.Sniper 3 - MOBO
