[SOLVED] PC shutting down randomly with orange/yellow led light ?
May 28, 2021
Hello!
Hope everyone's good.
Forgive me if there are terms that I might not be able to explain or understand right away, I am new in this PC world :)
I have bought my first pc last November 2020 with the following specs
Motherboard: Asus Tuf B450 Plus (with wifi)
CPU: AMD Ryzen 5 5600x
Memory: GSkill TridentZ RGB DDR4 3200 2x8GB
GPU : ASUS TUF GTX 1660 SUPER 8GB
Powersupply : EVGA 700BR 700Watts
Cpu cooler: Deepcool Gammax L240
Storage: TeamElite 256gb m.2
UPS: Silvertec 1000
First problem I have encountered : sometimes the computer hangs then I have found out my other HDD had some bad sectors so I decided to return it to the store and wait for the warranty/replacement
Then, there are some randomly shutdown on the PC so I decided to reformat (SSD) and reinstall again my windows but the randomly shutting down still continues
Then yesterday I have noticed there was a yellow/orange led light turn on near on my RAM
I already tried re-seating my RAM sticks but still keeps on restarting
Hope someone could help
Thanks
Would reseat parts first like ram and cpu, use fresh paste under the cpu cooler. See if it makes a diference. Can also reconnect the 8pin EPS connector=power for the cpu and the 24pin motherboard connector.
Did you update th bios in meantime? Or did the shop you bought it from?
The colors red/orange can mean different things, the red led suggests something is wrong with the cpu, orange doesn't exist, but yellow does, this points at the ram being a problem, combined that would get orange, but these are checked each at a time.
Hi Vic40
The shop I have bought the pc updated the bios for me make the CPU worked last year..
Regarding the color, I thought it was orange. sorry
I did try resetting the CMOS by removing the battery and putting it back ( I am not really sure if this is resetting the cmos) and hopefully this will work
Thank you for replying
