The PC is a Dell Studio XPS 9100.
Randomly and suddenly started shutting down within the last 2 days. It will attempt to automatically boot up after shutting down. Will turn off and on until it successfully boots to user login. The diagnostic page will also come up for a system repair on some occasions it does boot up succesfully.
It is old but cleaned a lot. I recently had problems with the heatsink not properly being installed correctly. I Fixed it but noticed I had accidentally cracked the plastic frame which holds it down to the motherboard and on top of the CPU. There are 4 screws and one is loose because of the broken frame. I applied thermal paste after not having any for years. Its been over a few months since I applied it so I do not think these are related to my current problem.
The computer seems to be overheating and shutting down to save power. The improper connection between the heatsink and the CPU could also be the problem. I doubt it is a power supply issue. It could also be a sudden power management setting being turned on.
I would be grateful for any help.
