PC Slow? Hard Drive Related? Any Help is Appreciated.
Jacob Emmons
12
Sometimes, my PC can get pretty slow, almost for no reason at all. Sometimes opening up a folder can be tedious. If I look at task manager, It'll show my disk usage at 100% at the times of slowness, and the main process using most of my disk isn't even really going at a high transfer rate. http://imgur.com/r7s7IvS
My Specs: i5 4670k, GTX 770, Asus z87-A, Western Digital Black 1T. (Western Digital
WD1002FAEX)
Thanks in advance,
Jacob.
Download the WD Data Lifeguard Diagnostic tool and run an extended test on the hard drive (Can take a few hours).
http://support.wd.com/product/download.asp?groupid=613&lang=en
Should give you a good indication if there are any problems with the drive.
If it does find problems I'm almost certain your drive will still be under warranty since you get 5 years on WD Black drives and the rest of your build looks less than 6 months old.
I have already used WD's datalifeguard, did the short test, and the long test, it said everything was good.
