Question PC Slow.. PLEASE HELP
Aug 23, 2019
31
I get frames from 80-20 and they just bounce. I have:
Ryzen 7 2700X,
Nvida 1660 Ti OC,
Bronze 450 PSU,
16 GB of DDR4 ram.
WDC WD10EZEX hard drive (Task manager usage is norm low)
Aug 23, 2019
31
woah woah woah slow down... what game are you playing and at what resolution to start out with
I play most of the time Sea Of Thieves, IRacing, sometimes Fortnite, PBUG, American Truck sim. They run on 1980X1080. When I turned on my PC this morning 1 fan is barely doing anything. Also, my disk usage is at 100% EDIT: It seems like its going a lot faster(the fan)
adamgrant520
90
4
565
7
Ryzen 7 2700X,
Nvida 1660 Ti OC,
Bronze 450 PSU,
16 GB of DDR4 ram.
could you expand on ""i get frames from 80-20 and they just bounce"" ? im not too sure what you mean with that, i assume you are getting 80 fps in your games but it is dropping to 20 fps at times ?
Aug 23, 2019
31
Yea, So I use recommended settings from Nvidia experience and it could be up to 120 one second and 27 the next. So iracing, for example, I could be on the track having 50 FPS (It should be more I'm pretty sure) then when I go into pit road it's down to 25! This is with settings recommended from iracing
adamgrant520
90
4
565
7
ok right, now i understand, i cant see any reason straight out the gate why your system might suffering like this! to start with. is your ram dual channel or single channel, basically do you have 1 stick of ram or do you have 2.
i know that quite a few games will perform badly with single channel ram
Aug 23, 2019
31
I have 2
Aug 23, 2019
31
stick with 1 thread
I posted this once and no one responded so ill try again. Im pretty sure my PC is running slower than it should FPS and loading times. Here is my specs
Ryzen 7 2700X
1660 Ti
450 PSU
Aug 23, 2019
31
memory speed?
cpu/gpu temp and usage during the game?
ram/hdd usage during the game?
malware scan your system?
fix the 100% disk usage yet?
Mem speed is 3000
CPU temps used to be really high but I fixed it now it doesnt get above 61 GPU is around 71
Hdd usage randomly gets to 100 at random times Mem usage is normally around 63
I did it about a month ago
Disk usage im not sure how to fix
