[SOLVED] PC slowly freezes after plugging in USB card reader ?
llxy
34
i7-8700
GTX 1660S
WD Blue SN550
B365M mobo
Corsair Vengeance RGB 2x8 (with 2 light enhancements)
CX650F RGB
I have never had any problems of freezing / crashing before, but when I plug in my USB Card Reader from Rocketek (https://www.amazon.ca/Reader-Rocketek-Memory-Speed-Windows/dp/B08CCVBL29), my computer slowly freezes. Any media stops playing, then file explorer doesn't show anything inside it and says "keep waiting". I can eventually open up task manager after waiting about 20 seconds, and when I restart file explorer, it doesn't open up again, leaving my task bar missing. At this point, my computer is unusable and I force restart it. This has happened yesterday, and just recently today.
I used to use this reader all the time with a different microSD.
How can I tell if this is an underlying issue, or the card reader? It usually happens as soon as I plug in the card reader. The card reader has a SanDisk Ultra 128GB microSD card in it.
Cheers
