PC sound drops when bass hits!
Tobbe00
Commendable
Mar 1, 2016
I need help with my PC sound, when I play music from for example spotify the sound drops when the bass hits and after the bass the audio turns up again. Its very annoiyng especially when I play games. I have tried with different equaizer programs but it doesn´t work.
I have read that some people have had this problem but no one have solved it for them, so I am extremly thankful if Iget an awnser.
Hi,
Please do try these troubleshooting steps that may help.
- Start by changing some settings with Sound.
- Right click on the speaker icon and select Playback Devices.
- Next is to right click on the default speaker selected and click on Properties.
- Click on Enhancements tab and put a check on "Disable all enhancements".
- Click Apply and OK then test it again.
If these first troubleshooting steps will not work try to uninstall/reinstall the sound driver.
- Go to Device Manager and uninstall the sound driver.
- Next is to download and install the latest driver from the manufacturers site.
- Once installed reboot your PC for all the changes to take effect.
- Test it once again after the reboot and see if the same problem will...
Hi,
- Test it once again after the reboot and see if the same problem will persist or not.
thanks for awnsering me, I removed realtek who were th sound driver for my pc and headphones. and now it uses microsoft as a sound driver and it works perfectly with the sound and no dropping.
THANK YOU SO MUCH!
