pc starts for 1 second then stops
CaseyR
27
ok this is my first pc build the pc starts for one second then stops liek the fans and everything starts then stop psu works tested in old pc mobo and cpu is brand new
Perhaps you had a loose connection when you first hooked everything thing up to the PSU. Since you removed it already to test in a different setup I suggest reassembling and trying again. If that does not work make sure you are hooked up to the correct video output for your monitor. Lastly a spec list and a more in depth description, as in when you power on do you see a display? Do all fans and drives light up and then it shuts off or do you never get video or anything and the fans just start spinning?
Do as crookedmouth said then see if it posts. If it does double check your temps in the bios. If they are good plug in one device at a time (with the power off each time) until it stops working. If it still wont boot make sure your cpu and ram are seated properly, and closely inspect your motherboard for any sgns of a short. Also recheck your wiring to make sure all cables are connected to the proper pins.
i double checked everything and i did forgot to mention i didnt have the ddr3 ram in when i tired it i just wanted to see if it would start up with the beep codes since i still need to order my ram this friday so idk if thats why it starts for 1 second and turns off or what but ima get my ram sometime next week and let you all know what happens
Use the Jumper method again.
http://forum-en.msi.com/index.php?topic=31222.msg178956#msg178956
Honestly I'm running out of ideas. It is coming down to the video cable or your monitor.
This is a long shot. Perhaps try to update the BIOS to a newer version using a USB stick and going blind. Get the update on a USB stick, unplug your hard drive and dvd-rom. Then boot up and hope that USB is one of the boot devices. You would have to blindly type the commands from the SOP.
http://download1.msi.com/files/downloads/mnu_exe/RichlandCPUSOP-EN.zip
Probably a little crazy.
video cable works and my monitor is my tv it works im useing it now to type lol and i cant get into bios i have no display its a brand new build first time its fireing up
