Question PC starts up but will not show display/Bios screen (First PC Build)
Jun 15, 2024
5
So I decided to build my first pc this year, as I had the money and affordability for it however I've run into a slight issue now that it's built. The motherboard lights up red for the CPU and lights up yellow for the RAM; it will not show any display/bios screen however the monitor recognizes that the pc is on. I'm starting to think the CPU may be faulty as I have checked the RAM, the cords, the monitor and everything but the CPU.
Parts List:
Case: Montech Mesh X3
CPU: AMD 7 7700x 8-Core, 16-thread
CPU Cooler: Thermalight Peerless Assassin 120 SE
Motherboard: MSI B650 Gaming Plus Wifi
Ram: Teamgroup T-Force Delta RGB DDR5 64g (2×32)
GPU: MSI Gaming GeForce RTX 3060 12gb
Internal Drive: Teamgroup MP33 2tb
Hard Drive: Western Digital 4tb
PSU: Corsair RM850e Fully Modular
I'm not saying if you changed their position, but take one out.Most likely, your mother is not cooperating.Some LED doesn't turn you on?
I have done that as well, I left one stick out and attempted to run it with only one stick. It still kept the yellow light up even with just one ram stick.
How long did you wait during the first boot. It can take over 10 mns before the systems shows anything on the screen.
Remove the GPU and connect the monitor to the motherboard.
I know I did not wait that long, first time going into this so I can try it that way and see if anything pops up
