I recently built my new PC. When I first tried to start it, nothing happened. I then removed all the power cords except the 20+4pin motherboard cable. when I turned on the computer the CPU and GPU fan started up. When I tried again with the CPU cord plugged in, it stopped working again. The fan on the PSU wasn't going at all during any of this.
Should a get a new PSU and return the one I have?
are there tests or things I could try?
Any help is appreciated
my spec are:
Asus M5A97 R2.0 ATX AM3+ Motherboard
AMD FX-6300 3.5GHz 6-Core Processor
G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory
Gigabyte GTX 950 2GB OC Graphics Card
SilverStone SFX-L 500W (But it says it compatible with ATX as well via a bracket)
my spec are:
