Hello! My PC is in an infinite loop of 3 second boot, shutdown, and restart right now.
Specs:
CPU: i5-10600K @5 GHz OC
CPU Cooler: Be Quiet Dark Rock Pro 4
Motherboard: GIGABYTE Z490 Aorus Master
RAM: HyperX Fury DDR4 RGB 8 GBx4 (32GB)
PSU: Seasonic 850W Focus Plus Gold Fully Modular
Case: Phanteks P300A Mesh
Storage: 1 TB WD Blue SN550, 1 TB WD Black SN 750, 3 TB WD 5400rpm hard drive, Samsung 850 240GB SSD (OS boot drive)
GPU: MSI RTX 3080 Ventus 3x OC
The system was actually originally on a Lian Li O11 Dynamic and everything worked perfectly fine. I decided to downsize my PC and placed my components in a Phanteks P300A. After completing the build though, the PC turns on for 3 seconds, shuts down and restarts itself. Then it goes on a boot loop every 1-2 seconds endlessly and makes a clicking noise whenever it restarts.
What I tried:
I am really suspecting that the motherboard has died on me at this point. I do not have any spare parts to conduct further tests and I can't borrow any components from my friends as they use their computer and have Ryzen in their systems.
Any advise/help is appreciated. Thank you!
Specs:
What I tried:
- Removing RAM and reseating them
- Removing CMOS battery and putting it back after 45 minutes
- Removing CPU from the motherboard and putting it back after inspecting the board for any bent pins, which there weren't any
- CMOS reset button behind the motherboard
- Removed both HDD and SSD
