PC stuck in Auto Repair Mode! Help!!
Pxlr
Help! Just as every day one morning I booted up my PC and used it just as normal. When I shut it down it sounded like it was restarting and suddenly booted into automatic repair mode. Now I cant even get into Windows 8 anymore when ever I turn on my PC. I have tried to restart it like it says and it just boots straight back into auto repair mode. Help!!
Try all the functions keys, restart and press f8 or the other function leys until it gives you the option to select boot device, then select the dvd drive, it will them say "press any key to boot from dvd" just tap any key on the keyboard
if you have th einstallation disk, run it, when it launches it will search for the problems, if it dosent find the solution, use the command prompt option and type: "bootrec.exe /fixboot" without the (") after that command, type: "bootrec.exe /fixmbr" again, without the quotes, then restart, if it dosent work then you may need to use a recovery disk if u created one or reinstall windows
I do have the installation disk. How do I boot it to search for the errors if the computer just boots staright into automatic repair mode?
