I recently purchased an ABS Master-Pro ALA078 Desktop PC, running Windows 10 Home (64 Bit). I had previously had issues with drivers, such as memory pooling blue screens and such, but never to this caliber. My PC seem seems to be stuck in a sort of boot loop. I power it on, the ABS logo flashes and startup seems normal, cuts to black, then for a split second the outline of a window flashes, then a message “Restoring your previous version of windows” occupies the screen until the screen cuts to black, I get a “no signal” message from my monitor, and the process starts again. (video on link bellow) I have tried nearly everything with my windows bootable media USB, and I have documented my trials and errors on this public Google doc- https://docs.google.com/document/d/1xe4073GTBPMokuS0GwrXf3jlurARwc32IVDb8nvVMZ4/edit?usp=sharing
I have had no luck whatsoever with almost every option imaginable. I'm not even sure how to do a clean reinstall of windows if that's the case. If anyone- anyone at all can help It would mean the absolute world. I just really want my computer back. Thank you so much if you can be any help at all!
